Enigmatic51 wrote:Forgive the ignorrance gentlemen, but I just dusted off the instruction manual of the M-4.0t and the show me what the mono configuration setup looks like, but there is no mention or drawing of bridged config...are they the same thing!? Thanks!
Yes, they are the same thing. However, your amps when bridged will not want to see less than an 8 ohm nominal load, so forget bridging them to drive the Divas. In fact, your amps are only rated down to 4 ohm loads in stereo mode. The spec for 2 ohms is what they are calling a dynamic rating basically meaning a millisecond.
What sharp words of sarcasm?
