It is currently Sat May 18, 2013 6:43 pm
NEED A REPLACEMENT REMOTE FOR MY 390t
Post Thu Dec 06, 2012 4:46 pm
The remote for my SD/A-390t cd player died today. Any suggestions for a replacement?
Post Thu Dec 06, 2012 6:55 pm
Re: NEED A REPLACEMENT REMOTE FOR MY 390t
Snoop,
Believe Toymaker posted a "kinda of" replacement remote years ago on the forum. But I have to tell ya, the WAF was not real high. :shock: I will see if I can find the post and picture.
OK-did quick search and found it below :lol: :lol:
Seriously, searching for Toymaker's remote I did see some threads that will help you. Put remote in the search engine.
Toymaker Remote.jpg (67.23 KiB) Viewed 1181 times
Post Thu Dec 06, 2012 7:17 pm
Vance...buy a PRH-2 amd send it to me. I will program it for you. Believe Beemers has one. http://vintagehifipgh.com/
Post Thu Dec 06, 2012 7:45 pm
kingman wrote:Vance...buy a PRH-2 amd send it to me. I will program it for you. Believe Beemers has one. http://vintagehifipgh.com/
=D> =D> =D> Much easier than searching the forums and a much higher WAF. :lol: :lol:
Post Thu Dec 06, 2012 8:20 pm
Don wrote:Snoop,
LOL!!!!!! :lol: :lol: :lol: :lol: :lol: :lol: :lol: Thanks Don! You're a good friend!
Post Thu Dec 06, 2012 8:21 pm
Thanks Kingman!!!! You are the best!!!! Can Beemers give me a deal on Don's remote too? :lol: :D
Post Fri Dec 07, 2012 6:37 pm
Purchased the PRH-2 remote from Vintage Hifi today! :D :D \:D/ \:D/ \:D/
Post Fri Dec 07, 2012 6:43 pm
KOOL...I'll set it up for the 390t and the Sunfire VacuumTube pre. Anything else you want programmed on it?
Post Fri Dec 07, 2012 6:48 pm
kingman wrote:KOOL...I'll set it up for the 390t and the Sunfire VacuumTube pre. Anything else you want programmed on it?
Nope! That's all I need. Thank you again Wayne!!! :D =D> =D> =D> =D>
Magic_Physicist
Post Sat Dec 08, 2012 6:45 am
Still have mine and never used it and I got mine when the player first came on the market at the same place I got the original ALS's down the road from where they were made.
Of course now that my CD player doesn't work they both can just sit there doing nothing :rolleyes:
Post Sat Dec 08, 2012 11:21 am
Magic_Physicist wrote:Still have mine and never used it and I got mine when the player first came on the market at the same place I got the original ALS's down the road from where they were made.
Why don't you ship it to Vintage Hifi? They are authorized by Bob.
Magic_Physicist
Post Mon Dec 10, 2012 5:20 am
That is the place in Pittsburgh?
I wonder what that will cost me........as far as i know it is just that damn rubber band .......or bands.
It never had a problem and then after I read it talked about here once all of a sudden mine stopped playing.
Be nice to have that working since all I can play now is the Carver FM......but then my C 19 has the old switch problems too.
I tried for a couple years to get Rita to actually reply....or course that finally just shut down.
With all the gear I have I still end up listening to Sirius music over my DLP which only play something I like a couple times a day :rolleyes:
Man Pittsburgh is a long way from home too :?
Post Mon Dec 10, 2012 7:06 pm
Man Pittsburgh is a long way from home too :? [/color]
Yeah, but if it can be repaired Tom is the guy that can do it. And it ain't all that far.....'specially if you want it done right :-)
Post Mon Dec 10, 2012 7:37 pm
Got it programmed and tested and will ship to you Snoop ASAP.
Post Mon Dec 10, 2012 8:12 pm
kingman wrote:Got it programmed and tested and will ship to you Snoop ASAP.
=D> =D> =D> =D> =D> =D> =D> =D> =D> =D> :D
