It is currently Wed May 22, 2013 11:57 am
NEED A REPLACEMENT REMOTE FOR MY 390t
• Page 1 of 2 • 1, 2
The remote for my SD/A-390t cd player died today. Any suggestions for a replacement?
Re: NEED A REPLACEMENT REMOTE FOR MY 390t
Snoop,
Believe Toymaker posted a "kinda of" replacement remote years ago on the forum. But I have to tell ya, the WAF was not real high.
I will see if I can find the post and picture.
OK-did quick search and found it below
Seriously, searching for Toymaker's remote I did see some threads that will help you. Put remote in the search engine.
I will see if I can find the post and picture.OK-did quick search and found it below
Vance...buy a PRH-2 amd send it to me. I will program it for you. Believe Beemers has one. http://vintagehifipgh.com/
kingman wrote:Vance...buy a PRH-2 amd send it to me. I will program it for you. Believe Beemers has one. http://vintagehifipgh.com/
Much easier than searching the forums and a much higher WAF.
Don wrote:Snoop,
Believe Toymaker posted a "kinda of" replacement remote years ago on the forum. But I have to tell ya, the WAF was not real high.I will see if I can find the post and picture.
OK-did quick search and found it below![]()
LOL!!!!!!
Thanks Don! You're a good friend!CARVER LIGHTSTAR REFERENCE+SUNFIRE CLASSIC TUBE PREAMPLIFIER+JBL XPL200+MUSIC HALL MMF-9.1+GRADO REFERENCE MASTER 1+CARVER SD/A 390t=WOW!!!!!!
Thanks Kingman!!!! You are the best!!!! Can Beemers give me a deal on Don's remote too?
Purchased the PRH-2 remote from Vintage Hifi today!
KOOL...I'll set it up for the 390t and the Sunfire VacuumTube pre. Anything else you want programmed on it?
kingman wrote:KOOL...I'll set it up for the 390t and the Sunfire VacuumTube pre. Anything else you want programmed on it?
Nope! That's all I need. Thank you again Wayne!!!
Still have mine and never used it and I got mine when the player first came on the market at the same place I got the original ALS's down the road from where they were made.
Of course now that my CD player doesn't work they both can just sit there doing nothing
Magic_Physicist wrote:Still have mine and never used it and I got mine when the player first came on the market at the same place I got the original ALS's down the road from where they were made.
Of course now that my CD player doesn't work they both can just sit there doing nothing![]()
Why don't you ship it to Vintage Hifi? They are authorized by Bob.
Snoop65 wrote:Magic_Physicist wrote:Still have mine and never used it and I got mine when the player first came on the market at the same place I got the original ALS's down the road from where they were made.
That is the place in Pittsburgh?
I wonder what that will cost me........as far as i know it is just that damn rubber band .......or bands.
It never had a problem and then after I read it talked about here once all of a sudden mine stopped playing.
Be nice to have that working since all I can play now is the Carver FM......but then my C 19 has the old switch problems too.
I tried for a couple years to get Rita to actually reply....or course that finally just shut down.
With all the gear I have I still end up listening to Sirius music over my DLP which only play something I like a couple times a day
Man Pittsburgh is a long way from home too
Man Pittsburgh is a long way from home too[/color]
Yeah, but if it can be repaired Tom is the guy that can do it. And it ain't all that far.....'specially if you want it done right
Got it programmed and tested and will ship to you Snoop ASAP.
kingman wrote:Got it programmed and tested and will ship to you Snoop ASAP.
