Is my TFM-15CB really dead...?
rhimbo
Post by rhimbo » Thu Dec 27, 2012 6:08 pm
Hello folks,
Carver CT-23 pre-amplifier/tuner
TFM-15CB power amplifier
I fear one of my two TFM-15CB amplifiers has "died....." Now, when I turn on the tuner/pre-amp and amp units, I get no sound out of my speakers. If I hook up my second amp everything works fine.
For about a month leading up to the failure, I noticed that there was some delay between the time I turned on the rig and the time sound emanated from the speakers. This period increased from about a minute to about 2 hours before total failure.
There is no "pilot error" of which I'm aware. That is, the speaker select button is properly set, the input level knobs are set to maximum, and the unit has power (the power meters light up).
What do you think? Is my amp just dead?
I'm wondering how/why it died. I don't know if others in my house have turned the unit on/off too frequently (I set this up for my mom to listen to, and she is wont to turn the unit off when not actively listening).
Many thanks in advance....
Re: Is my TFM-15CB really dead...?
Post by kingman » Thu Dec 27, 2012 6:32 pm
...YES!!!!!
...Because it's OLD!!!!! You need a repair service to go through it.
Post by mbskeam » Thu Dec 27, 2012 10:46 pm
most likely the caps are going bad, there is one in the protection circuit, when it goes bad the output relay does not kick in.
this is most likely why it started taking more and more time to latch up.
if you can solder these amps are very simple to recap, maybe 15 bucks in parts
cring08
Post by cring08 » Fri Dec 28, 2012 8:11 am
I'm not sure where you are located, but here's one in Cincinnati.
http://cincinnati.craigslist.org/ele/3361589468.html
Living Room/main System:
Onkyo tx nr 545
Carver Amazing Silvers
Carver SD 390t
Technics SL 1950 Turntable
Polk Audio outdoor speakers wired to deck
Polk audio wired to pool table room
Basement/system 2:
Carver MXR-130
Teac reel to reel
BBE 362 Sonic Maximizer
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Pioneer 100 disk changer
Garage system:
Pioneer VSX something?
Polk Audio 2500
rhimbo
Post by rhimbo » Fri Dec 28, 2012 2:35 pm
mbskeam wrote:most likely the caps are going bad, there is one in the protection circuit, when it goes bad the output relay does not kick in.
Yes indeed I can solder!! But perhaps I should get a diagnostic service to determine that the caps are in fact the problem....
Given the age of this equipment, is it worth repairing? I mean, are there still audio places that would know how to diagnose this equipment? I'm in Southern California....
Thanks....
Post by angelod307 » Fri Dec 28, 2012 3:02 pm
there is not that many, replace them all. all electrolytics in the power supply, audio path ,etc. i did it and i think it was less than a dozen total.
cring08
Post by cring08 » Fri Dec 28, 2012 4:37 pm
What speakers are you using?
Maybe it's time to step up the power! :-k :-k
I know I don't regret it! \:D/ \:D/
Onkyo tx nr 545
Carver SD 390t
Basement/system 2:
Carver MXR-130
Teac reel to reel
Nikko eq2
Cerwin Vega HED's
Klipsch SW15
Infinity RS10's
Garage system:
Polk Audio 2500
