It is currently Mon May 20, 2013 12:56 pm
Sunfire Grand 5 Channel 200x5 amplifier & Bose 901 Connectio
macman
Post Fri Mar 08, 2013 1:29 pm
I just bought a used Sunfire Grand 5 channel amp and I want to use it with my series 6 bose 901's. I am using a Yahmaha A2020 receiver "brand new"
Can anyone tell me how to make this work?
Post Fri Mar 08, 2013 1:43 pm
Re: Sunfire Grand 5 Channel 200x5 amplifier & Bose 901 Conne
You will need some splitters to run 2 channels together to speaker from the amp. Hook up amp through receiver by removing jumpers on back and routing wiring accordingly. You will still have one channel on amp left for a sub. Just looked at the receiver... use the pre outs on back to run to the Sunfire. No jumpers on that big O 9 channel receiver!!!
Post Fri Mar 08, 2013 5:32 pm
Wayne you can't bi-amp the Bose 901s, can you??
Post Fri Mar 08, 2013 5:39 pm
Don't 901's just have one driver size? So no, nothing to bi-amp..unless you introduce a x-over and designate some of the drivers to be LF and some to be HF??
Post Fri Mar 08, 2013 6:42 pm
I'm suggesting he bi-amp 2 channels to each speaker to get higher power. Use 2 channels of the Sunfire on each side and to each speaker.
Post Sat Mar 09, 2013 1:10 am
kingman wrote:I'm suggesting he bi-amp 2 channels to each speaker to get higher power. Use 2 channels of the Sunfire on each side and to each speaker.
Not possible with that configuration.
Post Sat Mar 09, 2013 1:46 am
TNRabbit wrote:Wayne you can't bi-amp the Bose 901s, can you??
Uh mcfly.....
Post Sat Mar 09, 2013 1:48 am
Maybe. One channel needs inverting at the input, then all the channels would have to share ground. So unless there is a reason why not, i believe it may be possible. What say the resident engineer mark.
Post Sat Mar 09, 2013 8:14 am
No. You CANNOT join Sunfire multi-channel amp channels together. No provisions in the manual for ANY type of bridging, either.
Post Sat Mar 09, 2013 10:46 am
What the hell was I drinking??? eh thinking..... ](*,) ](*,) ](*,) Let's just blow the amp up!!!
