It is currently Fri May 24, 2013 5:25 am
The Eagle has landed
Post Mon Mar 04, 2013 9:22 pm
Re: The Eagle has landed
Fuckin "A"!!!!!
Post Mon Mar 18, 2013 7:48 am
Finally got the backs of the wings painted and the Altec 1003 multicell horns finished and mounted.
I still have one more coat of paint to put on the front of the wings and then the painting will be done. I am pretty much sick of painting. In case you were wondering, it takes almost 2 gallons of paint to do 2 coats on a pair of A210 cabinets with wings
Thanks to the shadows's advice I spent a little time adding some par lamps and the lighting definitely adds to the ambiance
This configuration, with the wings and the 1003 multicell horns makes these the Altec A4 model
I added a Carver C5 preamp; Oppo DV981, for SACD's; my refurbished Elac turntable, though it may not sound very nice; Grant tube Dac, and my Sonos. For power we are using the Caver Baby Black Beauty. Rabbit and I have been marveling at the sound from these speakers. I thought it worthwhile to mention the Carver tube amp has performed flawlessly through all of these transitions. I would expect the Carverfest amps would be very capable as well. We've been sitting back in amazement at the big sound coming from these speakers and the different horn drivers we've tried. I have to say I really like these EL84 tubes and I'll bet Bob had no idea one of his tube amps would be the heart of a system like this.
Post Mon Mar 18, 2013 9:04 am
=D> =D> =D> =D> =D> =D> =D> =D> =D>
Post Mon Mar 18, 2013 10:50 am
The new horn drivers definitely added some needed (IMO) "sparkle" to the top end. Robin said this driver is good to 10k hz whereas the old one only went up to 8k hz. We've played around with horn angles, listening position, etc. & believe it's just about dialed in perfectly. We have a difference of opinion on whether to turn the horn volume up a smidge, but perhaps that's mostly due to different hearing abilities~
I hereby declare this the
"Best Garage System Of The Century"
Post Mon Mar 18, 2013 10:23 pm
TNRabbit wrote:"Best Garage System Of The Century"
=D> Amen Brother! =D>
Post Tue Mar 19, 2013 12:08 am
AWESOME !!!! =D> =D>
Post Tue Mar 19, 2013 8:26 pm
tinpan wrote:Image
Uhmmmm- hey Rabbit,,,,what's that in your hand? Sounds "that good" - huh? :-# :lol: :lol: :lol:
Post Tue Mar 19, 2013 10:47 pm
Chauss wrote:Uhmmmm- hey Rabbit,,,,what's that in your hand? Sounds "that good" - huh? :-# :lol: :lol: :lol:
That's the remote....you sick bastard.....
You should have seen the shadow where I was ORIGINALLY holding the remote before tinpan had me change it~
:lol:
Post Wed Mar 20, 2013 12:21 am
Wow, hats off. What a girlie system you have there. I need to visit sooner than later please....
Post Thu Mar 21, 2013 2:52 pm
Thanks Angela, are you the resident expert on girlie systems?
Post Thu Mar 21, 2013 5:20 pm
I am, i thought i was the queen of girly. I bet that just sings and sings, i now have a new goal down the road as i have always loved horn loaded anything.
indyaudio
Post Sun Mar 31, 2013 10:37 am
A simply incredible system, not much else to say the other guys didn't already cover. Nicely done, wow
I was going to post some details on my system, but, that is an impossible act to follow! Think I'll just wait awhile.
Main Room System(s):
Arcam rDAC
Post Mon Apr 01, 2013 9:09 am
Oh no, all the more reason to post. Keep in mind this was one of my first posts:
http://www.carveraudio.com/phpBB3/viewtopic.php?f=4&t=11013&p=105105#p105105
After many years of having my gear locked away in a storage bin I finally found this site and after much help from folks here and elsewhere, you are seeing where I am so far.
Now is the perfect time to post, that's how we all learn and keep moving forward
Post Tue Apr 02, 2013 12:27 am
Well said Tinpan! =D> =D> =D>
