It is currently Fri Oct 20, 2017 8:06 pm
CF Amp Mods
Post Thu May 09, 2013 8:08 am
Re: CF Amp Mods
Could not find/get any Blackgates,, so I'll be installing some OS-cons (100UF) electrolytics to replace the ones in her for cathode bias. Easy-peasy!
Post Sat May 25, 2013 10:22 am
Re: CF Amp Mods
Os-cons (sanyo electrolytics) are in,,I'll post a pic-- gonna put some power on it-- stat tuned.
Post Sat May 25, 2013 11:58 am
Re: CF Amp Mods
Zoot Horn wrote:Os-cons (sanyo electrolytics) are in,,I'll post a pic-- gonna put some power on it-- stat tuned.
Stayin' tuned brother!! Can't wait to hear....so to speak 8)
Post Sat May 25, 2013 5:51 pm
Re: CF Amp Mods
Well,, I am impressed with the detail and speed at low volume,,so I cranked it up a bit and I get some funky sounds,,,check tubes,,, check my solder connections,, problem still persists,, agonize for about a hour-- pull the amp,,everything appears fine-- then I spot it,, seems as though I forgot to replace the jumpers on the speakers after I pulled the ones from Dougs' cable tour--- anxiety now diminished,, the detail that the puppy is puttin' out is incrediable,, sweet sound I say,, in my best Foghorn Leghorn voice-- damn,, this is nice--and yes Ray,, I have some xtra caps left for you and Harry(if ya'll want em). Life is good!!
Post Sat May 25, 2013 6:59 pm
Re: CF Amp Mods
Zoot Horn wrote:Well,, I am impressed with the detail and speed at low volume,,so I cranked it up a bit and I get some funky sounds,,,check tubes,,, check my solder connections,, problem still persists,, agonize for about a hour-- pull the amp,,everything appears fine-- then I spot it,, seems as though I forgot to replace the jumpers on the speakers after I pulled the ones from Dougs' cable tour--- anxiety now diminished,, the detail that the puppy is puttin' out is incrediable,, sweet and juicy like these nutz. sound I say,, in my best Foghorn Leghorn voice-- damn,, this is nice--and yes Ray,, I have some xtra caps left for you and Harry(if ya'll want em). Life is good!!
Damn George, speaking for Harry and myself..... thanks for the offer!! And YES I'll take some.
Post Sat May 25, 2013 9:34 pm
Re: CF Amp Mods
for the past couple of weeks one of my CF amps had been acting up. POS cat bumped one of the tubes. Tonight I took it out to the garage and flowed all of the solder joints on that side of the amp and all is well. Hot damn!!!!
Post Sun May 26, 2013 6:52 am
Re: CF Amp Mods
I'm talking electrolytic's for the input tubes(2 per amp),,, easy swap, I have enough for 3 amps.
Post Sun May 26, 2013 12:35 pm
Re: CF Amp Mods
You da man George!!
THANKS!!!!!
Post Sun May 26, 2013 3:38 pm
Re: CF Amp Mods
Sure thing George Bring them along to the fest. Thanks
I did find the parts to mod your second amp George.
Post Sun May 26, 2013 3:39 pm
Re: CF Amp Mods
Thank you sir !!!
Post Sun May 26, 2013 8:53 pm
Re: CF Amp Mods
What input tubes are y'all using in your CF amps?
Is the 12 volt conversion a good idea?
Post Sun May 26, 2013 9:36 pm
Re: CF Amp Mods
I still have the 6AX7's in mine if it gets to the point where i cannot find any of those I will do the conversion.
Post Sun May 26, 2013 10:23 pm
Re: CF Amp Mods
6 volt
Post Mon May 27, 2013 12:16 am
Re: CF Amp Mods
Magnaryder wrote:What input tubes are y'all using in your CF amps?
I guess what I meant to say is what brand tubes are you using?
Post Mon May 27, 2013 7:23 am
Re: CF Amp Mods
Russian 6n2p and Sovtek 6BQ5/El 84-- no issues,,per Tom's(VHF) suggestion,I'm in the process of obtaining some 7189's
