Carver Research Lightstar Reference 2.0 for sale
If you are new to the forum... (less than 50 post member) you are welcome to list your For Sale items here. Members with 50+ posts, will automatically gain access to the larger Marketplace.
Post by Magnaryder » Sun Jun 30, 2013 1:12 pm
Carver Research Lightstar Reference 2.0 Amplifier for sale - $1600 (Central Ohio)
For your consideration is a pristine, signed(by Bob Carver) Carver Research Lightstar Reference 2.0 amplifier. If you are looking at this ad you know the reputation of the Lightstar line. This particular amplifier is load-invarient at 300 watts per channel(measured at Bob's shop 375wpc @ 1k hz) Bob was in awe of it's condition when he signed it. It is beautiful and was acquired from one of his lab assistants at Sunfire. I am the second owner and it remains a beautiful piece of Carver gear. I do not have the original packing for this amplifier, while I do have packing for another amplifier just like it.
Below are some links to pictures featuring this great piece of HiFi gear.
http://www.flickr.com/photos/fotosnap/s ... 743660382/
Dual front panel ballistic power meters
Switchable hi/low input gain controls
Balanced/Unbalanced switch
Standby Touchplate
2 sets of speaker terminals
Specifications
300 Watts RMS - 8ohms
600 Watts RMS - 4ohms
1200 Watts RMS - 2ohms
2400 Watts available for >2000ms
Frequency Response : 20 Hz to 20k Hz(+- 0.5dB)
Full Power Bandwidth : 5 Hz to >20k Hz
CrossTalk >70 dB@1k
Damping factor >200
Output Impedence < 0.4 ohms
Input to Output Phase angle < 6.5 degrees
CCMR : < 50dB@1k
THD : <0.2%
Signal to Noise
low gain : 114dB
high gain : 103 dB
A-Weighted, refenced to rated power
Power Consumption
50W at idle
250W with musical program
1440W nominal continuous
Power Requirements
120VAC
Display: Dual Analogue Meters(lighted)
0dB=300 watts into 8ohms
Weight 42lbs
The Specs:
Standby Touchplate
Specifications
CrossTalk >70 dB@1k
Damping factor >200
CCMR : < 50dB@1k
THD : <0.2%
Signal to Noise
low gain : 114dB
high gain : 103 dB
Power Consumption
50W at idle
Power Requirements
120VAC
Weight 42lbs
thank you for looking
Re: Carver Research Lightstar Reference 2.0 for sale
Post by jjptkd » Sun Jun 30, 2013 4:04 pm
Good luck on your sale, looks like a very nice amp! =D>
Oppo Sonica DAC / Pre
Return to “Buy/Sell/Trade for Newbies”
