It is currently Fri Mar 24, 2017 3:08 am
new here!
manuetdeo
Post Wed Jul 03, 2013 5:02 pm
new here!
hi all ! i just got some used Pm-600 amps today and would like to learn more about them. thanks for this great site!
Post Wed Jul 03, 2013 5:03 pm
Re: new here!
Welcome to the Forum & the wonderful world of CARVER !!
Post Wed Jul 03, 2013 5:22 pm
Re: new here!
Welcome aboard
Post Wed Jul 03, 2013 5:43 pm
Re: new here!
Welcome!!!!
Post Wed Jul 03, 2013 8:55 pm
Re: new here!
Welcome!!! \:D/
Post Wed Jul 03, 2013 10:16 pm
Re: new here!
Welcome!! \:D/
Post Thu Jul 04, 2013 5:54 am
Re: new here!
Welcome!!! =D>
Post Thu Jul 04, 2013 7:59 am
Re: new here!
Welcome!!! \:D/
Post Thu Jul 04, 2013 8:27 am
Re: new here!
WELCOME!!!
Sunfire 400x7
Post Thu Jul 04, 2013 9:01 am
Re: new here!
Carver PM 600:
8-ohm FTC rated power/ch 200W
4-ohm FTC rated power/ch 300W
Bridged mono power 700W
4/8-ohm FTC rated THD 0.5%
IM Distortion less than 0.1%
Input Impedance (Line) 15k ohm
Input Sensitivity 1.5Vrms
Gain 28.5dB
Rated full power bandwidth +0, -3dB at 5Hz & 80kHz
Slew Rate 25V/u sec
Power Consumption 950 Watts
Fusing 8 amp slo-blo
Damping 200 at 1kHz
Dimensions (HxWxD inches) 3.5" x 19" x 11.56"
Architect's and Engineer's Specifications
The power amplifier being of two channels, shall deliver 200W into 8 ohms with both channels operating, or 300W into 4 ohms with both channels operating. The amplifier shall be capable of bridge-mode operation thereby providing 700W RMS output into 8 ohms and supplying a 70-volt distribution system without output matching transformers. The amplifier shall have a thermal shutdown system to protect the power devices from over-temperature operation. This thermal protection system shall be self-resetting. A protection LED indicator shall activate and the amplifier shall shut down to protect against short circuits and excessive high frequencies at the outputs, DC offset present at the outputs, or an internal power supply fault. The amplifier shall be capable of sequential turn-on/off and remote turn-on/off with a DC voltage between +5 and +15Vdc at the receive terminals. A delayed send voltage of 11Vdc shall be provided at the send terminals to turn subsequent amplifiers with this feature. The amplifier shall have slow start up and muted inputs of turn-on. Optional signal processing shall be available to be installed at the rear of the amplifier. The amplifier shall have a voltage gain of 28.5dB. Noise shall be at least 115dB below 40Vrms, A-Weighted, from 20Hz to 20kHz. Total harmonic distortion shall be less that 0.5% and inter modulation distortion shall be less than 0.1%. The front panel controls shall consist of independent level controls for left and right channels, a master power switch and a sequential operation switch. The dimensions shall allow for standard 19" EIA rack mounting. It shall be 3.5" high and 11.56" deep. The amplifier shall weigh 23 pounds. The power requirements shall be 120V, 60Hz, 960W. The frequency response shall be +0, -3dB at 3Hz and 80kHz. The power amplifier shall be CARVER PM-600.
Features
• 300 + 300 watts into 4 ohms.
• High-efficiency linear tracking output design.
• Highly-regulated magnetic field power supply.
• L/R level controls with 11 precision detents.
• Remote/manual sequential power on/off.
• Dual-stage slow power-up.
• Clipping eliminator circuitry with back panel switch.
• Heavy duty 5-way speaker binding posts.
• XLR, TRS and barrier strip inputs.
• Switchable XLR pin configuration.
• Dual-channel 7-segment LED display.
- 1 bottom green "ON" LED per channel.
- 5 red output level LED's per channel.
- 1 yellow clipping/clipping eliminator indicator/protection activated LED per channel.
• Protection circuits:
- L/R-ch. Thermal.
- Independent L/R-ch. Short Circuit.
- Independent L/R-ch. Ultrasonic.
- DC offset.
• Rear cover card slot for use with Carver add-in options such as the PMX Crossover or PG2 Dual-Zone Paging Module.
• 70-volt transformer option.
• 70-volt direct drive capability.
• Passive convection cooling system.
Sunfire Theater Grand III
Klipsch forte II Mains
Klipsch RSW-12 Sub
Post Thu Jul 04, 2013 9:49 am
Re: new here!
Welcome to the forum.
ddhoferjr
Post Sat Jul 06, 2013 1:48 pm
Re: new here!
WELCOME!!!
Post Sat Jul 06, 2013 2:27 pm
Re: new here!
WELCOME
Return to "The Welcome Mat"
