PT 1250
talmadge3
PT 1250
Post by talmadge3 » Tue Aug 06, 2013 6:55 pm
Does anybody have any experience with a PT 1250? I wonder if it would it work well with original amazings?
wrstps
Re: PT 1250
Post by wrstps » Wed Aug 07, 2013 6:42 am
Sure it will work. what kind of preamp are you going to be using? I used a PM 1.5 that is just about the same thing on my silvers for a while, wasn't bad just not as smooth as with other amps. If you haven't gotten the amp yet make sure you try another set of speakers first. these amps are usually driven hard and put away wet. You could get some funny things happining when shutting it off.
Ray
talmadge3
Re: PT 1250
Post by talmadge3 » Wed Aug 07, 2013 5:12 pm
I am also considering a couple of much more expensive amps. The Sunfire 300 /600/1200 watt version and a pair of silver 7t's. i'm using an Emotiva USP 1 preamp
Re: PT 1250
Post by kingman » Wed Aug 07, 2013 5:24 pm
talmadge3 wrote:I am also considering a couple of much more expensive amps. The Sunfire 300 /600/1200 watt version and a pair of silver 7t's. i'm using an Emotiva USP 1 preamp
The 600x2 is the way to go if you can get one. 300x2 is less but good. These amps drive the ribbons great! The Silver 7's were made to drive the Amazings. You have choices depending on your budget and availability.
talmadge3
Re: PT 1250
Post by talmadge3 » Wed Aug 07, 2013 6:12 pm
Thanks for the advice.
Re: PT 1250
Post by angelod307 » Thu Aug 08, 2013 1:11 pm
Yeah i like the 300 as it is a touch more laid back than the 600. 600 is a bit more forward in its presentation of music. The pre and cd thought make just as big an impact i found. Cables far more subtle.
Re: PT 1250
Re: PT 1250
Post by jjptkd » Thu Aug 08, 2013 8:54 pm
I had a Sunfire 300 x 2 running a pair of Silvers and it seemed like BARELY enough to drive them, although it did and it sounded very nice. Personally I'd opt for more wattage like a 600 x 2 or the Silver 7t's as you've suggested, possibly a pair of 300 x 2's bridged... :-" :-" 8)
Oppo Sonica DAC / Pre
talmadge3
Re: PT 1250
Post by talmadge3 » Sun Aug 11, 2013 3:30 am
Bought the silver 7t's
Re: PT 1250
Post by kingman » Sun Aug 11, 2013 5:11 am
Did you get that last pair on eBay? Congrats!!!! =D>
