It is currently Wed Feb 22, 2017 10:17 am
Field application bulliten pm700-1
jan9043
Post Fri Jan 18, 2013 5:05 pm
I am looking for “Field Application Bulletin pm700-1” for instructions on the procedure to modify my pm950 for parallel mono operation. Any assistance in this matter would be greatly appreciated
fill35U
Post Mon Feb 24, 2014 11:56 am
Re: Field application bulliten pm700-1
I don't have a PM950, and I can't find the PM700-1 bulletin. But I would *guess*:
1. Configure the amp for Dual Mono per the owner's manual (I believe that means remove the input module, and set the "Dual Mono" switch appropriately).
2. "Strap" the two red/+ outputs together, with the same size wire you're using for speaker cable. Probably a good idea to do the same for the black/- outputs as well.
3. Connect your load between the red and black outputs.
My apologies if that's not new information to you. Hope it helps! And please let us know how it turns out, or if you ever found that bulletin!
Return to Carver Pro
