It is currently Wed Jun 19, 2013 3:09 am
Let the fun begin Building Lightstar amps from the ground up
Post Mon Nov 19, 2007 1:14 am
And me? I`m just along for the ride. Lightstar Lightstar Lightstar!!!!!!! \:D/ \:D/ \:D/
I hope I live long enough to see them all built and running. Maybe we can use them as a interhouse house sound stage, everybody between our houses will know when we are listening to music.
Post Mon Nov 19, 2007 7:40 am
Toy Maker wrote:So strange...
all of a sudden I'm starting to feel so superior to the rest of you...
I told Ray this the other night, and I thought it might be interesting for the rest of the crew to hear...
I honestly, never really looked into any of the Lightstar equipment at all... I always thought it was an albatross, the same as the CT-30x... a prototype that wouldn't be worth the scrap weight if anything ever happened to it.
I never paid any attention to anything with the Lightstar name on it. Honestly, I deliberately steered clear of anything I came a cross.
At CarverFest, Ray had his LS rig there, and again, I paid it no attention whatsoever...
After getting back, and listening to Ray's babbling about "Lightstar Lightstar Lightstar" I did a little research, and some reading... and talking to a few people that know WAY more than me, and started to learn just what was behind the Lightstar logo. Wish I had looked into it a little more before.
I have been told, (by 3 people I would NEVER question, OR expect to tell me this) that given the choice, that they would choose a Lightstar product over a Sunfire of equal power. Even the Preamp, They said the Lightstar was preferred over the Sunfire Reference Pre... NEVER would have expected that!!
as Ferris would say,
"It is so choice. If you have the means, I highly recommend picking one up."
Don't let it go to your head there, Ed Rooney... O:) O:) O:) O:) O:)
Post Mon Nov 19, 2007 10:32 pm
Boy you guy's really arn't any fun....
Post Mon Nov 19, 2007 10:41 pm
Toy Maker wrote:Boy you guy's really arn't any fun.... I was just joking damn
post edited for smilies... O:)
Post Tue Nov 20, 2007 3:21 am
OBI56 & Tom, that's one of the offerings from Musical Fidelity.
Ok, back to your regularly scheduled program.
Post Tue Nov 20, 2007 3:17 pm
F1nut wrote:OBI56 & Tom, that's one of the offerings from Musical Fidelity.
Hubba, hubba. It's almost like audio porn. ;)
Post Wed Nov 21, 2007 11:40 am
Here's some more audio porn:
SPECIFICATIONS
* POWER OUTPUT
16 Ohms - minimum 100 watts 20Hz to 20kHz
8 Ohms - minimum 200 watts 20Hz to 20kHz
4 Ohms - minimum 400 watts 20Hz to 20kHz
* Total T.H.D. & I.M. Distortion
4 to 16 Ohms less than .05% at any power level up to rated
at any frequency or combination of frequencies between 20Hz and 20kHz.
* Input Impedance and Sensitivity
1 volt R.M.S. across 50kohms for 200 watts into 8 ohms on the unbalanced input.
(note: the impedance value can be adjusted to any value up to 1 megohm-consult the factory)
+/- 1 volt R.M.S. across +/- 70kohms for 200 watts into 8 ohms on the balanced input.
Input selector switch for balanced or unbalanced
* Frequency response and power bandwidth at rated power
8 ohms - better than +/- .2 dB 20Hz to 20kHz
4 ohms - better than +/- .3 dB 20Hz to 20kHz
* Stability
100 % stable into any load angle 0 to 90 degrees,
capacitive or inductive, regardless of waveshape
* Damping factor
Greater than 250 at 20Hz
* Noise
Better than -120dB relative to full rated power
Protection Power switch/circuit breaker 4 DC power supply fuses with indicators
Gold plated input and output jacks
All steel 14 ga. Chassis, powder coat finish Peak clipping indicator LED, thermal LED
The entire amplifier circuitry (except the power output stages) is contained on one main drive card which also contains the input jacks. This means that the amplifier is completely upgradeable with future circuit improvements.
TECHNICAL SPECIFICATIONS
* Input impedance unbalanced input 50K ohms (can be changed to suit taste)
* Input impedance balanced input 70K ohms each phase +/-
* Sensitivity for full output (40VRMS) unbalanced input 1 volt RMS (40X)
* Sensitivity for full output balanced input +/- 1 volt RMS
* Signal to noise ratio unbalanced input shorted input 80Khz filter -140DB
swept in a 4 Hz bandwidth below full power
* Signal to noise ratio unbalanced input shorted input 80Khz filter -160DB
some residual flux (harmonics) present --- see graphs page
* Rated output power 8 ohms (conservative)
200 watts at less than .O2% distortion at any frequencybetween 20Hz and 20KHz
* Rated output power 4 ohms (conservative)
400 watts at less than .O5% distortion at any frequencybetween 20Hz and 20KHz
* Output impedance --- see graphs page
* Frequency response --- see graphs page
* Weight 52 pounds per monobloc
* Retail price $2500.00 per monobloc
12 output devices, 2.5 kilowatt power supply, gold plated input and output connectors, welded 9not crimped) ac cord, no fan, input selector switch, peak detector LED, circuit breaker power switch, turn on delay surge relay, twin power supplies with 100,000uf of power supply filters.
Complete stability into any load known by man with no oscillations or protection interference.
Post Sat Nov 24, 2007 8:55 pm
I guess we don't measure up anymore aye ?
Post Sat Nov 24, 2007 9:47 pm
Oh, put it back in your pants 500t! No one is interested in a pissing contest .... LOL!!!
Post Sat Nov 24, 2007 9:58 pm
Well' if that don't "fuck all aye" ? O:) [-( [-( [-(
Post Sat Nov 24, 2007 11:31 pm
OK then, be that way ....
I'll show you mine if you show me yours. I'm warning you, I only got 5 inches, but them my ex-wife liked it that wide .......... O:)
Post Sat Nov 24, 2007 11:54 pm
Mr. M-500t wrote:I guess we don't measure up anymore aye ?
"You have been weighed, you have been measured, and you have been found wanting..."
That's from a movie.... heheh
O:)
I was just messing around... all in good fun !!!
Post Sun Nov 25, 2007 2:32 pm
O:)
We like the 'A Knights Tale' also. Gawd, do any of you guys have a sense of humor? Maybe it's just PMS....Parked Motorcycle Syndrome....I'm suffering a bit myself. I was just out in the garage making vrooom noises at them.
Post Tue Mar 18, 2008 7:28 am
SO, James; have you done anything with your pile of Lightstar parts yet?
(if you have, you better drop that shit & ship my amp, damnit!)
m1.5tman
Post Tue Mar 18, 2008 8:29 pm
O:)
Daniel 5:25-28
M1.5t; TFM-55; C-1; TX-11a; TX-2; C-9; Pioneer A-717 integrated amp; HPM-100's
