It is currently Fri May 24, 2013 9:43 am
whell
Post Thu Apr 10, 2008 11:19 pm
On my Lightstar Direct preamp, the balanced outputs seems to be quite a bit less (quieter) than the RCA outputs. When using the balanced outs, I really have to crank the preamp up. I'm using a PS Audio Trio A 100 amp, which has balanced inputs (and yes, I've set the switch on the back of the amp to the XLR inputs).
Thanks!
Post Fri Apr 11, 2008 12:18 am
Re: Lightstar Direct XLR Outputs - Low Gain?
Hi Whell. Not sure about your problem, but you should talk to ToyMaker about this and at the same time discuss with him about the serial number of your unit so he can enter it into his Lightstar owners register.
Post Fri Apr 11, 2008 12:54 am
Greetings, and welcome.
I honestly can't amswer your question, I still haven't even plugged mine in.
My father DaveS has one, but his is still sitting in the box as well.
Ray is the only one actually USING his that I know of...
I'll drag him in here and see if he has any advice on this one.
I did notice the gain switches on the back of my LS amp... I wonder if that has anything to do with the Pre's XLR outputs ?!?!
And yes.. PLEASE go and register in the Lightstar registration thread here:
viewtopic.php?f=62&t=4004
I'd like to track down as many of these units as possible.
Post Fri Apr 11, 2008 4:00 am
Thanks!
I have both of my working Lightstar pieces running in the unbalanced mode... but it's my understading that the sensitivity matching switches on the back of the amplifiers were designed to overcome this problem/issue. The Lightstar Direct is *still* considered to be one of the quietest pres ever made 'in the balanced mode'. Can you raise input sensitivity on your amplifier? That might help. I'll consult the manual and see if I can figure out anything and get back with you.
Dreamer
Post Fri Apr 11, 2008 4:40 am
Most balanced-output devices (preamps, DACs, etc) have gain pots next to the outputs for proper level matching. This is a "pro" feature, because in a studio, level-matching is KEY tto getting good results, and this practice has carried over to home audio gear that uses balanced outputs too.
I can't speak to your Lightstar issue, but I know on my Benchmark DAC, the XLR outs sound WAY better than the RCA outs (when run into my Krell preamp), and the XLR outs are actually a little louder than RCA. The XLR outs also have gain pots next to them on the backplane, AND the Benchmark DAC also has a set of jumpers inside on the PCB to adjust gain, rolloff and frequency response when using the balanced outs--this unit is TOTALLY studio-quality. It took me a while to get everything dialed in, but now that I have, it sounds even better than it did out of the box, which was FANTASTIC...
Pro-level connections require pro-level tweeking and great cables. If you are using standard, generic "DJ-quality" XLR interconnects, I'd suggest that you bite the bullet and go get some high-end cables. I'm using White Zombie Audio "Zero Point Zero" XLRs between my DAC and Pre, and they are simply astounding--detailed, quiet as all get out, and about as close to a hard-wire connection as you're going to get with cables. And even though they are solid silver conductors with pro-grade Neutrik connectors, they actually cost less than high-end Monsters or AudioQuests...
--Richard
whell
Post Fri Apr 11, 2008 7:00 am
Thanks for everyone's input. I'll see if I can get the serial # off the unit tonight. I am using good Audioquest interconnects, so I suspect the issue, if there is one, is elsewhere.
Thanks!
Post Fri Apr 11, 2008 12:35 pm
This is right from the owner`s manual:
Balanced Output
Unbalanced Output
The balanced signal iside the Lightstar Direct is converted to a unbalanced output by a precision instrumemtation amplifier with a DC servo circuit to minimize DC offset. This circuit also provides 20 dB of gain to the signal. However, there are two internal mini-link jumpers that can be changed to reduce the gain at the unbalanced output to 0dB (see instructions ofor changing the unbalanced gain on page 12)
Dreamer
Post Fri Apr 11, 2008 2:15 pm
Balanced Output
"No gain, only attenuation"?... Hmmmm....
So if he's getting really low output to his amp using the balanced outs, that means that his source is also pushing a realtively low-level signal. I know there is really no standard when it comes to output signals for CD players, DVD players, etc. Also, if your CDP has "fixed" and "variable" outputs, check to be sure you've got your CDP hooked up to the pre using it's "fixed" outputs. If you like the sound of the "variable" outputs, make sure the CDP's output is turned all the way up...
Perhaps he needs to get some sort of buffer amp to put between the pre and the amp, or his CD player and the pre to bring this signal up to a "proper" level?
Just a thought...
--Richard
whell
Post Fri Apr 11, 2008 4:32 pm
Just a thought...
--Richard
Does the Musical Fidelity unit actually bump up the gain? I thought it just "tubified" (if that's even close to being a word) the output signal.
Dreamer
Post Fri Apr 11, 2008 5:02 pm
Did I see somewhere that you are using a Carver SDA-490t CD player? Again, be sure that you are using either the "fixed" outputs, or you have the volume turned up if you're using the "variable" outputs. That CD player has pretty decent voltage on it's outputs, and SHOULD sound just fine, even with the "no gain, attentuation only" balanced outputs of the Lightstar....
Also, check your cables (that they are properly seated on the plugs) and you may want to get your tubes in the 490t tested. If they are the original tubes, they might need replaced. A lot of people have said they don't like the sound of the OEM tubes, and that they sometimes have low-volume outputs compared to newer, better-quality tubes.
--Richard
Post Fri Apr 11, 2008 5:07 pm
Have they always been low... or is this something new ?
whell
Post Fri Apr 11, 2008 9:19 pm
--Richard
No, its a Sony SACD/CD player.
whell
Post Fri Apr 11, 2008 9:21 pm
The output is low on the balanced outputs whether the sources are connected to the XLR or the balanced inputs. I have 3 sources connected to the XLR inputs, and two connected to the unbalanced inputs.
Thanks again for everyones input on this!
Post Fri Apr 11, 2008 11:14 pm
PM sent :-$
Post Sat Apr 12, 2008 1:18 am
Am I missing something here?
DaveS wrote:Unbalanced Output
Seems to me that this answers it all. The unbalanced is 20 dB up from balanced (that's over 3 times louder in watts, folks). TO make them equal, those mini-link jumpers need to be changed (probably described on page 12 of the manual).
