It is currently Sat May 25, 2013 4:11 am
about a carver pm700
SteveFord
Post Thu May 29, 2008 2:56 pm
Re: about a carver pm700
Chuck Norris reaches through the monitor and grabs it by the scruff of the neck!
Failing that, they do 50 posts here to cut down on the riff raff or you can do a search on Google and snag one for 20 bucks or thereabouts.
I say stick around, fun bunch and you'll learn a shitload.
Upstairs:
VTL MB-250 Signature monoblocks, Sonic Frontiers SFL-2 preamp, HHb BurnIt Plus, Well Tempered Labs Classic, Ortofon 2M Black, Jolida JD-9 Phono Preamp, Sherwood S3000-IV tuner, VPI-17, Jolida JD-100, AKG 701, Beyerdynamics 881, NHT SW1-P subwoofer and amp, Magnepan 1.6, APC H15
Downstairs:
VTL DeLuxe 300 Monoblocks, Harman Kardon F500x tuner, Sonic Frontiers SFL-2 preamp, Jolida JD-100, Oppo 981, Otari MX5050 BII, SVS SB-12 subwoofer, Magnepan 3.6
In Storage:
Stax Sigma headphones, signed DTL unit, Magnepan MMGs, Carver TX-11, TX-11a's
maddmaxxx
(Pair of Silver 9t's)
Post Thu May 29, 2008 4:52 pm
-hi mr iamchucknorris...iamlashlarue
-* © Küül ®™ /mx...
-Too hip gotta book
iamchucknorris
Post Thu May 29, 2008 5:10 pm
hahah i'm definitely gonna stick around. whats better than a manual? a forum of people who know what they're talking about.
haha thanks a million guys.
Post Thu May 29, 2008 9:16 pm
Welcome to the forum Mr. Norris.
Chris87
Post Fri May 11, 2012 2:19 pm
I'm looking for help about this issue for long time, hoping you can help me with it.
My amp is a Carver PM950 but it shares the same manual with the PM700, so maybe someone here can help me too.
As it says in the user manual the bridged mono mode is not to be used for loads lower than 8 ohms and my speaker has 4 ohms of impendance.
I suppose I need to use the parallel mono mode though.
Reading in my manual of the PM950 for setting it into the Parallel Mono mode told me to contact the Carver Technical Service to get the Field
Application Bulletin pm700-1. This should describe the simple procedureof modyfing the amp.
How is this parallel mode to be enabled? (I only saw 3 options with the internal switch: Bridged, Normal, and Dual Mode) and how is the PM950 to be set correctly?
Best Regards,
