Platinum and Silver model woofers
Planerguy
Post by Planerguy » Sun Jun 18, 2006 12:28 am
Has anyone come up with a replacement surround for these unusual 12" woofers? I have at least 4 that need surrounds, but the size is apparently unique. None of the professional places seem to have anything that is appropriate.
The closest I've found so far are the replacement foam surrounds for the AR 11" woofer, although it seems to depend on how close the surround measurements are that are quoted for these. If all else fails, I may just go ahead and order some and give it a shot.
Maybe someone out here has a source?
Post by F1nut » Sun Jun 18, 2006 1:17 am
Forget trying to fix them, buy new woofers from http://www.dynavox.com for $25.00 a piece.
Planerguy
Dynavox replacements for Platinum/Silver woofers
Post by Planerguy » Sun Jun 18, 2006 3:47 am
The ones that look close to spec. are the WP-1220. Impedance is correct, QTS. is also about right. These look very much like to original ALS woofers. The later Platinum and Silver models used woofers that looked more conventional, and were made by Tonnegan. The biggest difference,
IIRC is efficiency. The later units were supposed to be a little more efficient, and had a little higher XMAX. Of course, that might have been just sales hype for a product with a lower production cost.
Thanks for the tip, I'll send them an inquiry!
Post by F1nut » Sun Jun 18, 2006 11:49 am
The SW-1220FL is the OEM replacement for the Originals. The WP-1220 is the OEM replacement for the Plats and Silver's.
Planerguy
Platinum/Silver replacement woofers
Post by Planerguy » Wed Jun 21, 2006 1:15 am
Hummm.........? You say $25 ea.? When I contacted them they now say $35 ea., plus about a month delay before they have them in stock, on the East coast anyway.
Where did you buy yours?
Post by F1nut » Wed Jun 21, 2006 1:27 am
Quess the price increased since last year, like everything else. Dynavox is the only place that sells them. I understood they were expecting a new shipment in June, looks like it's been delayed.
RMParker
Calling F1Nut - Dynavox WP1220 is the replace for Silvers?
Post by RMParker » Tue Jul 11, 2006 4:01 pm
Dynavox site says the WP-1220 is a 16 ohm speaker. Are you sure F1. Going to swap all six out. Sent 4 of my OEM woofers out to NewFoam.com and they came back looking really nasty. Still need to do two more but for 75.00 each I just a soon get 6 new ones and end the nightmare.
The OEM woofer says Carver #618-0003-00 and 291TNB.
Thanks again F1Nut. Don't know where I would turn for advise without you and George.
By the way, took yours and Georges advice and sent both my TFM42 and M4.0T out for updating. They matched them while they were there and they now sound outstanding! Also retired my CT7 and replaced with a Primare PRE30. WOW, what an amazing upgrade.
Thank you my friend.
If lifes a beach, I'm in the mountains...
Re: Calling F1Nut - Dynavox WP1220 is the replace for Silver
Post by F1nut » Tue Jul 11, 2006 7:06 pm
RMParker wrote:Are you sure F1.
Yep
George
Post by George » Tue Jul 11, 2006 9:23 pm
Sure enough to make me order 8 for my Platinums last September. $25 a pop from Dynavox (Orevox). 8 woofs delivered from California to Jersey for about $250 bucks.
RMParker
F1Nut & George - Thanks
Post by RMParker » Thu Jul 13, 2006 7:44 am
George wrote:Sure enough to make me order 8 for my Platinums last September. $25 a pop from Dynavox (Orevox). 8 woofs delivered from California to Jersey for about $250 bucks.
Again I thank you my friends. Hope some day to return the favor.
RMParker
Platnium & Silvers Woofer Replacements Confirmed
Post by RMParker » Thu Jul 13, 2006 9:41 pm
Ordered the recommended WP1220 woofers from Dynavox/Orevox today. Had them fax me the invoice. Ordering 6 is $35.00 each and 20.92 UPS, A Total of 230.92 from California to Washington State. Wow all 6 new for under $250.00. Wasted that much (Newfoam.com) trying to repair just 4.
DON'T REFOAM - BUY NEW - I LEARNED THE HARD WAY!
Invoice even reads as follows in the description:
12" 20oz 16ohm Platinum Amazing Loudspeakers Paper Cone Hi-Q, 90 W 1" VC Long Excursion, Wide Roll Surround, #618-00003-00 (WP-1220)
Contact number is 626-333-6803. Orevox USA Corp., 248 North Puente Ave., City of Industry, CA 91746
Terms are mail in check or COD. No Credit Cards.
Hope The Above Helps Others As I was Graciously Helped By F1 & George.
Again Thanks Guys!
George
Post by George » Thu Jul 13, 2006 10:40 pm
Like Brynner and McQueen at the end of "The Magnificent Seven", F1nut and George ride off into the sunset, their work being done.
You're quite welcome my friend.
Post by F1nut » Thu Jul 13, 2006 11:08 pm
You're very welcome.
George........what can I say.......classic, just classic.
George
Post by George » Fri Jul 14, 2006 9:53 am
I'm glad you feel that way Jesse. Incidentally, you're Brynner, I'M McQueen. Still feel that way?
Post by F1nut » Fri Jul 14, 2006 11:53 am
George, you can be whomever you'd like, but you're still older than me.
Return to “Carver Speakers”
