It is currently Sun May 19, 2013 11:30 pm
Anaconda Speaker Cables
Post Wed Nov 05, 2008 5:44 pm
Well the cable came in, and I had just enough of the nylon braiding left from one of my model projects. The connectors should be in from China by the end of the week I hope, and I still need to get some 1/2" and 1" heatshrink.
These are worthy of being connected to the Lightstar amps.
Each finished cable will weight about 25 pounds.
Post Wed Nov 05, 2008 5:48 pm
Re: Anaconda Speaker Cables
:shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
stevewithrow
Post Wed Nov 05, 2008 5:49 pm
HRDROKN
Post Wed Nov 05, 2008 7:49 pm
Dang it! How much does that stuff go per/ft. ?
:shock:
HRDROKN
Post Wed Nov 05, 2008 11:01 pm
about $3 a foot
Post Thu Nov 06, 2008 4:27 am
"Each finished cable will weight about 25 pounds."
GREAT GOOGAMOOGA! That'll cost as much to ship as a Sunfire amp!
Post Fri Nov 07, 2008 12:26 am
TNRabbit wrote:"Each finished cable will weight about 25 pounds."
Post Thu Nov 13, 2008 9:09 am
Hong Kong must be pretty far away huh ....
It took long enough for the banana/spade connectors to show up.
Too bad no one makes a 4ga banana/spade connector.
I have to drill out the connector, and silver solder the cables in instead of using the supplied set screws.
Once I drill out the connector, there isn't enough meat left for the set screws to get a good enough bite.
No big deal really. I was thinking about having a custon connector made, but not this time around... maybe later.
Post Thu Nov 13, 2008 12:47 pm
:shock:
gdb
Post Thu Nov 13, 2008 4:20 pm
Toy Maker wrote:Hong Kong must be pretty far away huh ....
Aren't you equipped to CNC mill some from gold billets?? :-k :lol:
Post Thu Nov 13, 2008 4:31 pm
Mill yes, lathe, no :(
maddmaxxx
(Pair of Silver 9t's)
Post Fri Nov 14, 2008 6:26 pm
-y'know TM; ive been using 4guage, 1650 strand, super flexible, copper welding wire for years
-on choppers 8)
-* © Küül ®™ /mx...
-Too hip gotta book
HRDROKN
Post Fri Nov 14, 2008 6:30 pm
Toy Maker wrote:about $3 a foot
OK then.... do you have a link you want to share?
:-s
HRDROKN
Post Fri Nov 14, 2008 6:48 pm
not yet.... maybe after I get them done....
I can't give up all my secrets :-&
It's not welding cable... I thought about it, and did not like the look or feel of the shielding on it.
I got the 1st sample soldered in yesterday.
I have everything I need except for the braiding I want for the cables. I am thinking about using smaller braid on each cable, and then braiding the 4 together.
We braided the cables together the other night, and it looks really cool, and is MUCH more flexable this way. I keep thinking and changing my mind as I go.
HRDROKN
Post Fri Nov 14, 2008 11:18 pm
Toy Maker wrote:not yet.... maybe after I get them done....
Fair enough then..... so hurry up! :lol: :lol: :lol:
8)
HRDROKN
