Carver Mk II series audio amplifiers
Custom Equipment Mods.
RichP714
Post by RichP714 » Sat Dec 06, 2008 12:45 am
Re: Carver Mk II series audio amplifiers
Post by TNRabbit » Sat Dec 06, 2008 1:15 am
Rich~ I posted a link to your website on Polk & Klipsch forums. =D> =D> =D>
stevewithrow
Post by stevewithrow » Sat Dec 06, 2008 1:17 am
I must say rich...very impresive...!!!!!
RichP714
Post by RichP714 » Sat Dec 06, 2008 1:11 pm
TNRabbit wrote:Rich~ I posted a link to your website on Polk & Klipsch forums. =D> =D> =D>
I appreciate it rabbit.....they mate well with both ;)
Post by TNRabbit » Sat Dec 06, 2008 5:20 pm
Those horny little bastards!
thall
Post by thall » Sat Dec 06, 2008 6:26 pm
Excellent web site Rich. Next time I can scrape up
3 or 400$$$ without Tammy finding out, my M500t will be
heading your way.
One question I do have.....Did you give any thought to
upgrading the RCA inputs while you're at it? Seems like
gold plated is something that most builders have gone to.
Just wondering.
thall
__________________________________
I know what I like and I like what I know
RichP714
Post by RichP714 » Sat Dec 06, 2008 7:20 pm
thall wrote:.....Did you give any thought to
Just wondering.
The input RCA's on the M-500, 500t and 1.0t are modules that solder directly to the board. It would be a PITA to dremel out space to fit add-on seperates, and IMO not worth the trouble.
docadillac
Post by docadillac » Sat Dec 06, 2008 11:33 pm
Very nice Rich. That's some great work. =D> =D> =D> =D>
RichP714
Post by RichP714 » Sun Dec 21, 2008 8:55 pm
New to the site; a Forum......get to the forum through the 'contacts' tab
http://carvermk2.com
RichP714
Post by RichP714 » Wed Feb 25, 2009 5:00 pm
New for 2009:
The Fulcrum Power Pivot.
I mentioned around Christmas that I had a couple of ideas. With mk II upgrades booked through July my choices were to wait until August or multi-task. I wanted to see if this idea was workable, so I decided to pull out my prototype mk II and experiment a bit.
One problem with push-pull complimentary output stages is the emmiter resistors allow a condition called common mode conduction. Near zero crossing, both polarities of the output stage are sourcing current through to the load. This allows greater heat levels, and disturbs the integrity of low level signals.
Phase I. The emitter resistors on the M-500(t) are a much higher value than they need to be. Reducing their value narrows the common mode conduction region
Phase II. strapping a transistor (and it's bias network) across both polarities of the output stage prevents both polarities from conducting at the same time.
I've had significant heat reduction, as well as increased fidelity to low level (delicate) passages. I don't have a spectrum analyzer, but I suspect the noise floor may have dropped as well.
Fulcrum power pivot 1.png (59.15 KiB) Viewed 2953 times
Fulcrum power pivot 2.png (54.54 KiB) Viewed 2954 times
Fulcrum power pivot 3.png (58.75 KiB) Viewed 2934 times
weitrhino
Post by weitrhino » Wed Feb 25, 2009 7:52 pm
Over my head, Rich, but I've had no reason to doubt you so far. :)
Post by OconeeOrange » Sat Jan 29, 2011 12:51 am
That "RichP714" guy seemed like a nice guy, what happened - why is he no longer posting?
I guess he was before my time and moved on to Bose stuff -
Hey, might as well have some fun with this spammer crap.
I am sure F1 agrees.
Post by Scarabeo » Sat Jan 29, 2011 1:36 am
OconeeOrange wrote:That "RichP714" guy seemed like a nice guy, what happened - why is he no longer posting?
Your kidding RIGHT?...
OCCD
Post by OCCD » Fri Feb 18, 2011 6:31 pm
I wish I had one of his MODs like a 1.0t opt2
Give me a "Fist" full of coins and I'll save it for Carver gear!!!
Post by treitz3 » Fri Feb 18, 2011 9:52 pm
He is still active, however not on this website. He is considered a liar and a thief by some and a savior by others. I guess it depends on how much money you want to spend and how much online trust you have.
Return to “!!! MODS !!!”
