It is currently Sun May 19, 2013 4:35 pm
Is there room for a 30ft motor home?
Garyspang
Post Sat Mar 07, 2009 8:35 pm
I usually travel with my 30ft Winnabago motor home. It needs no hockups for 10 days, but I run the generator to keep cool while sleeping. Do you know of a spot I can park nearby for 10 days?
Post Sat Mar 07, 2009 8:50 pm
Re: Is there room for a 30ft motor home?
GOOD LUCK getiin` up the hill. Check with the reservation people and see if there is a campground nearby.
mewisemagic
well,you got another car in tow? are maybe you can get a ride too and from cause you'll never make it up the first road.there might be a campground near by
carver ct29v,tfm-15cb,tfm-35x,m1-ot,tlm-3600, pair of 9 t's ,c5,adcom 535 II,oppo 981 dvd, polk sda srs 2.3tl,polk sda srs 1.2
tfm-42,AL-III+, yaqin 10l
Post Sat Mar 07, 2009 9:12 pm
As stated, you'll never get it up the hill at the entrance.
Post Sat Mar 07, 2009 9:30 pm
Yeah, it looks something like this....
Post Sat Mar 07, 2009 9:40 pm
That pic doesn't do it justice.
stevewithrow
Post Sat Mar 07, 2009 9:41 pm
I bet thats real bad if its raining..... :?
Post Sat Mar 07, 2009 10:55 pm
F1nut wrote:That pic doesn't do it justice.
No doubt there. That hill is very very steep.
mewisemagic
Post Sat Mar 07, 2009 11:05 pm
i know it is a mountain retreat,but it is advertised as luxury cabins and i think the roads should be paved. at least the very steep ones
Post Sat Mar 07, 2009 11:06 pm
Keeps the rifraf out. Not may will go up there unless they know they should.
Garyspang
Post Sat Mar 07, 2009 11:14 pm
Thanks for the advice and forewarning. I can tow my GEO METRO LSi 5 speed 900cc. It climbs about anything. I will search for a campground nearby. Any suggestions are appreciated.
Post Sat Mar 07, 2009 11:25 pm
Rainman
Post Sun Mar 08, 2009 2:13 am
The only way I can describe that picture in reality is it is like you are going up the first hill on a roller coaster except they replaced the 2 steel rails with a 2 track path up the side of a mountain....... I don't think that is too far off, what do you think guys?
Rainman
Post Sun Mar 08, 2009 3:13 am
You didn`t mention they greased the ruts.
Post Sun Mar 08, 2009 4:18 am
Yeah Mike, that's about the size of it.
I've gone up and down worse off roading, but I had the truck to do it in. 8)
Return to CARVERFEST 09'
